Опубликована: 06 авг 2012, 10:05
Тема: frame house forum
The erection of house does not require any major construction equipment and the availability of a labor force. This saves. But a plus is not only that. You've seen what happens on building sites in and around them: a mud, deep ruts, a damaged appearance, etc. Maybe it's natural beauty inspired you to build there. A recovery? Again the costs. The frame construction to avoid it and keep the original beauty of the area.
It will take years. In addition to problems of a complete overhaul in stone houses there is also a questions with a reconstruction, an extension of new rooms, as well as a demolition of old houses. So, to attach a guest room or to expand a living room, you have to arrange a major excavation of basement ( after all brick walls are hard - for example, a square meter of wall weighs about 360-400 kg (102 bricks of 3, 5 kg, without a mortar, and a reinforcing mesh), to provide an access for a heavy machinery, to hire a team which will work about 2-3 months straight at your side. In short, one summer is gone. A if you do an addition on the same frame technology, you can limit the minimum pier foundation (the weight of 1 square meter of wall is about 30-70 kg even if the wall "shrinks", with a 10-ton car jack you can everything correct), to do the same work yourself with a friend or a relative for a couple of weeks without the involvement of professional employees for a substantially less money, not breaking your favorite site!
