Опубликована: 09 апр 2021, 08:49
1100 aluminum coil specification
Product name: 1100 aluminum coil
Alloy: 1100
Temper: O/H12/H14/H18, Etc
Width: 100-2650mm
Port of loading: Qingdao
Lead time: 30days
1100 Aluminum coil description
1100 aluminum sheet coil is one of the pure aluminum coil series product with the aluminum content 99%.
It cannot be heat treated to strengthen, but has small density, good plasticity, high corrosion resistance, electrical conductivity and thermal conductivity.The production process for 1100 aluminum coil is relatively simple, and price is relatively cheap,it is the most commonly used series in conventional industry.
It is usually used for usages which require good forming, processing performance, high corrosion resistance, but does not require high strength, such as storage equipment and food and chemical handling, hollow hardware processed by spinning, punching and welding combination keys , Reflectors, nameplates, etc.
1100 Aluminum coil application/exact usage
1100 aluminum sheet coil is widely used in daily necessities, constructions, kitchenware, decorations, lighting appliances, reflectors, heat sinks, road signs, electronics, lamps, nameplates, electrical appliances, stamping parts and other products etc, requirements are not high.
The chemical composition of 1060 aluminum coil
Al(%)Si (%)Fe(%)Cu (%)Mg(%)Zn (%)Mn(%)Ti(%)V (%)
99.600.950.950.05-0.2/0.10.05/0.05Aluminum For Industry supplier
website:http://www.hwaluminum.com/aluminum-for-idustry/
Alloy: 1100
Width: 100-2650mm
Lead time: 30days
