Опубликована: 02 окт 2012, 11:55
The situation is this:
We want to build a house in the bosom of nature in the Bryansk region, a few kilometers from the village where there are relatives. We plan to do everything together without superintendents, builders, and other people that could deceive. An excavator and a similar technique in that area is excluded because the expected location is in a field, surrounded by the forest. Communications like a plumbing and a heating through the woods is not easy to carry out and we do not need it because we are planning to make a brick oven on the first floor (by the way is also very important moment in the construction sector). It has two floors, with a loft. Everything is a country style. For a permanent residence! The fact that we are not builders, and we can not solve a lot of questions. We decided to find out in advance all the best, and then you do.
It is difficult but not spare forces.
1. First, which material to use? a brick? an aerocrete? or a ceramics? (Not wood), or from any other material? (Given that everything will be done with hand tools, no stationary machine tools).
2. How to make the ceiling (a floor) between the second and the first floor? Which is the material better and easier? Let me remind you no heavy equipment like a crane.
3. Since electricity is not available there, we will keep products in the cellar. Then the question arises, what about the foundation, as it is better to do in this thread? Again, how deep and how generally do a foundation?
4. In the Bryansk region the climate is not always pleasant, especially in the winter, as all that then build at minus 30 fridge did not the whole house? In the summer there will be a sun. As smooth as climatic difficulties?
5. "plus - minus" I would like to know from experts in these cases for how much we expect? (Doing it all ourselves).
We sketched the plan of the house, each floor with two rooms of, it turns out a rectangle box of two floors of the same size, divided by the partition in the middle. (Only 4 rooms)
Just to be close to this house is a quite big room for the cattle at the top of which is a barn (again, from what and how to make it safe, for centuries, and the cattle in the winter is not dead)
Adjacent to another room for the wood, the same workshop (to fix that and so on.)
Adjoining the building is not so important at this stage, right now, we should determine what and how to build the house itself. We live in it and raise our children. The question is very important. I understand that the project is capacious, complicated by many factors, and therefore appealed to the people's way with his wisdom. Please help us with tips on how to? what? from what? I read a lot of sites.
We are looking forward to your assistance.
