Опубликована: 10 дек 2012, 12:27
Тема: how to frame house walls
Welcome, dear friends. We start preparing for a demo unit wall from cement wood on which we can see in a real life the various options of the exterior of building. It remains to decide what kinds of options of external finishes were suited. I will express my opinion below, and ask you to give yours. Just the size of the wall is limited, so all the options will not suit. It is necessary to select the most good.
Wall options (finishing only on one side):
Length - 3.2-3.5 m
Height - 1.2-1.4.
Width - 0.3 m (i.e, one block from arbolit)
On the wall you have to install a laying net as it will be seen how it works and how it is insulated. Also, on the wall there will be a small window to show how the bridge is arranged over the windows. So, I think to finish the basement with tiles or a plaster for each option.
The external finish to the wall, you should arrange for at least 4 versions, with two of them - the exterior design by a facade plaster. I want to show a facade system by layers to see everything. My options are so:
1) The facade system on materials of a higher price segment: Cerezit, Baumit, Kreyzel, Baukolor etc. Layers will be according to the manufacturer requirements.
2) I need the most economical option based on a conventional cement-sand or cement-lime plaster with addition of a perlite. A finish with the minimum required number of layers and therefore a work may have any proven ways to save in such cases, for example when the paint is mixed with filler, or a PVA glue is added, etc. A cement wood has a good permeability to water vapor, on average, our units will be 0.12 - 0.17 mg / (m • h • Pa) and it should be considered.
3) Siding on a crate from bars.
4) A ventilated facade on colored fiber cement slabs - also on a crate of bars.
Or remove the paragraph number 3, and instead it, add a facade render system from the average price range: Knauf, Atlas.
I wish that were reflected all price options, especially now there is a crisis. So, speak with me, and if there are those who have done something like that, I am ready to listen to your piece of advice or just to chat. Best regards,
Length - 3.2-3.5 m
Height - 1.2-1.4.
