First, we stacked timbers on a euro flax as a jute fabric was not on sale...But we noticed that a flax absorbs the moisture very quickly, and we changed as soon as we had the opportunity for a jute. It is quite another matter. And on the forum the people often argued that the jute is practical. We will also caulk with the jute. And why do you take such a wide ribbon for caulking? By the way, as far as I know, a linen is cheaper than a jute. Price for today:
a tow (jute) 15 6 + / -1 80 360
a tow (jute) 15 8 + / -1 80 400
a tow (jute) 15 10 + / -1 80 500
a tow (linen) 15 10.8 50 450
In practice: a grinding machine (where the tape is rolling around) is only good for the finish grinding of logs. Well, like, so it looks like trimmed logs, round and straight. Plus, the manufacturer is also important (as the tape was rolling fast). Primary removal of projections, twigs, irregularities and a residual bark at a reasonable rate is only possible when using grinders with a petal nozzle. This is not a metal brush (God forbid!), this is when pieces of abrasive paper glued on the disk. For the first pass it is better to take the forty. Attempts to process a house in the drill attachments IMHO are counterproductive. First of all, not all nozzles rotate without beating (don’t take ones that have the axis chucked in a drill, and set separately from the disk, and then screw in it on the thread - this is a diversion!), Secondly, it is too slow and an awkward tool. My optimum, two grinders with the forty (one cools down, the other works) and a grinding machine for the indoor use.
The theme intersects with others, but I want to make my two cents here: Here's my personal experience of caulking - who are interested there are pictures with the instruction: about caulking. Why I chose a jute tow. Pluses:
- It contains more lignin than in a flax and other seal materials.
- It does not crumble when it dries as a moss.
- Birds and other animals do not drag it, but they made such attempts while the tape sticking out after packing of logs but then they quickly abandoned
- Easy installation of a log house. You unrolled the tape and finished.
- If you get wet, it dries quickly.
A minus:
- The high cost of natural fiber with no additives.
I bought for myself a fabric 200 x 2 mm in the rolls containing a jute 90% and a linen 10%. A more common and therefore cheaper with containing 50 x 50. And I looked it, but it differ dramatically not only in color, but of a structure (in touch). The euro linen was also looked, but I didn’t like it. It is not elastic and looks like the material for boots. So, I'm wondering how to make a "primary" caulking. I made one wall, pushing a spatula in the lower ends of a dangling tow in the cracks between the logs, but the gap is not large, and after shrinkage of the framework, I think, in general problem will caulk.
And in this way can not leave, tow collects moisture after rain and I think hurts the log.
