Опубликована: 10 окт 2011, 15:06
Russian, Canadian, Norwegian log cabin. What to choose?
Russian, Canadian, Norwegian log house.
When we taking about building a log house or a log cabin bath, mostly, people are thinkimg about material? A log or a timber? Less commonly, a carriage.
But it is important not only a material of a frame, but the way of cutting. Over the centuries a carpentry craft perfected and there are currently more than ten main types of logging.
A combination of various wooden parts together is called an angle joint.
A proper manufacturing process involves the creation of angle joints which will perceive the loads transmitted to them, and the coherent parts of the angle joint should fit tightly to each other in all surface of connection. When building exterior walls exposed to precipitation, it’s important no stagnant water in angle joints.
A log cabin consists of crowns. Four logs laid horizontally and connected at the corners by the angle joints, make a crown. The crown is placed on the crown, resulting in a frame house.
There are two basic types of connections all logs: whith a residue and without residue.
A felling of a frame house includes three basic operations: cutting of corners, cutting of grooves and edging of logs.
For a long time in Russia, a wooden frame house and baths were built by hand using only an axe, adze, chisel, plane and a trace ... An Axe and an adze. 1 – a wood axe 2 – a potes, 3 – a plane (a long scraper), 4 –a trace, 5 –an adze, 6 – a bit 7 – a vista, 8 – a carpenter's ax.
At the present time in Russia an arrangement of wooden corner joints of wood buildings is regulated by State Standard 30974-2002. The State Standard applies to corner, T-junctions of cobbled log wall used in construction and repair of wooden houses and baths. The State Standard applies to commercial and DIY manufacturing. The requirements of State Standart 30974-2002 are recommended.
