The project of the house 147 sq.m from profiled beams
  • Опубликована: 17 янв 2012, 15:02
  • Автор: buldozer
buldozer
Тема: Re: The project of the house 147 sq.m from profiled beams
Today, we brought the last car with timbers, the building has gradually passed a half way, today or tomorrow, we will install the joists on the second floor. The question airises how to heat the house, I planned a diesel, but the price of 20 rubles per liter that is too much, when I had planned, it costed 15 rubles per liter. or a solid-propellant boiler as a primary source, and the electric boiler to maintain?. Who does have a solution to the problem of heating, please, share. :roll:
bill
Buldozer, good afternoon!
Please, write if you were happy with a Lestekom and their designer Dimitry and their timbers?. Were there any nuances?
Sincerely, yours.
buldozer
Yes, I happy with LesTekom, and Dmitry has a separate respect, a well done!!, well, nuances are everywhere, but they were resolved quickly, without any dispute and questions!. Well done!. Since this was my first experience of construction and I can not compare with anything, you can safely put a solid five, even considering different nuances!. High-quality timbers and a high-quality work at the assembly erase in memory a little slightest friction, but you can not escape or hide from it, that's a real life, a human factor, but the people are different, the main thing that we have reached a common denominator!. The first floor are ready now!!, I think in the same spirit will be the building of the second floor and the closing of the roof!. Based on the responses in the house construction, I am doing very good, it pleases me very much!. My first experience will not be disappointed by the bitterness of defeat!. Thank you to all responded!. There is still the second floor, a roof and what is not unimportant – a cleaning of the area, a tidy storage of residual material, a house cleaning!.
bill
Buldozer, do they have a standard contract for manufacture and supply of the design or discussed?. The timer supply in several stages is specifically set in the contract?. And do you have a contract or an agreement with the building team?.
If you prefer, you can write in personal mail.
buldozer
I am continuing to post a spring construction,photoshoot, I have been there this morning, I post pics that rosed before my eyes. The builders have already put the beams on the second floor, I offer the views from the various rooms of the house. Supporting pillars that I chose 200 x 200, while the foreman was offering 150 x 150 – but I didn’t listen to the pros, now, I think they catch the eye, and even if they are changed then, will be a strong trouble?. Help me, please!. But I was upset, but the guys said that the fragment was well matched, and they woild lock it with the screws, drowning caps. well, this part of the axis is located at the rear of the house, but none the less. The winter does not want to give up their rights to spring this year, then the log house is covered, then it is opened with an enviable regularity. The beams were treated with a red antiseptic called “Senezh”, the experience of the builders shows that when it rains and snow, an antiseptic and to lubricate the stain timber itself, or rather the red stains on the walls. When the weather is normal, they will cut the film, and the protruding ends before the treatment of the ends, look at the ends below, there is no PSUL and the ends are processed.
bill
When they cut everything, ask them to give them to you, and you are in turn, calculate the total length, and then multiply the money and throw away.
baltazar
Good afternoon!. How much does it cost the shipping?. Write it in personal mail, please. With a choice of heating thre is a same problem. Today, I unequivocally rejected the diesel fuel as it is expensive and it stinks. As the main boiler is wood, the wood costs not so much and a weight of the proposals to maintain the temperature at 6 kW electric, it's for my home. In my absence, thre is an electric heating, I set for five degres and went out, than I came, I lit the wood, and most importantly, this a budget version, wood boilers are not very expensive and there is a possibility to convert to a gas heting, and the electric heating takes up a ttle space and, of course, a radiant floor on the first floor.
bill
Is it possible to tell in detail , if it not so difficult for you. How much does an electiric boiler consume at these hands?. Is it a quickly heated when you visit?. A warm floor on a wooden base and filled in the oven?. A consumption of the firewood?. How do you often toss?. In general, you can describe in detail. Yeahh, do you have the photo of boiler?.
baltazar
So, once again, when you assembled, then you wrapped by a cellophane? So, how?.
And now, how much will they cut, and what is covered and wrapped within the next crown will remain there?.
IMHO, it will become damp and begin the process of decay, you should to wrap with a jute, so, then there will no vibration on the walls.
Summer
A very good house!! It looks great!!. We have an almost identical building. How do you cover the log house?. What is the roof?.
bill
buldozer
- I have the dried wood. I plan to cover the roof until the May holidays and to make a soft drain. Then, will be a painting and the time to order windows and doors.
expert
What kind of heating will you chose?.
buldozer
I think a gas heating. On the first floor we will have the underfloor heating + radiators, on the second floor - only radiators. As soon as possible, the film must be removed, the probability of blue underneath is very high. That's interesting. What is the moisture of your timber house now?.
I had on the arrival 28-29% at the ends. After the assembly was from 15 to 22%.
bill
And how do you measure the humidity?. Perhaps such a device is available in stores, if so, where can I buy it?.
buldozer
Dear forum users!. Tell me please, how much does it cost the work on the installation of a casing oscillator bars in the openings of doors and windows in my house with a view of the groove under the bar. Everyone responded thanks in advance. This is the price per unit of the door and the window, and here is the installation itself, but just work on the installation of a casing oscillator bar, without the installation of windows and doors, the house will still settle.
bill
My installation of windows and doors costs:
1. windows – 1700 rubles;
2. doors – 2200 rubles. I bought it last year when I had to control my initial grief-contractors. The price was around 5,000 rubles.
I bought it in Kaluga, Scientific st. At the weekend, I will look uo the name... and call.
buldozer
Tel me please if it is posssible to cut and tan to sset the casing stones in the openings with a natural moisture, as the house will be closed by the temporary roof?.
Thank you, very much!. They promised to give a moisture meter for the weekend.
bill
If you are not doing a full posts, then leave the jumpers, and the jumper bar over and under it.
buldozer
And what is included in a full post?. And if I could do it on a bar with a natural humidity?.
