what is log home chinking
  • Среднее: 3.0 (2 голосов)
  • Опубликована: 30 ноя 2012, 15:00
  • Автор: constructor
Summer
Тема: Re: what is log home chinking
Not so easy to cover up them! These absorb PVA ends like a sponge! Three layers and you can not see it either, there's nothing to trim there. And not only the PVA, but everything! I poured into them, but all the same some logs were broken. On the south side of the house. If the ends of the grind will not, then color the same house with the Remmers. It is quite easy to sand it! When I polished even the metal clips from the stapler clears in the dust in a second by a grinding wheel. We bought a new composition from Neomid Thor Plus. And we will try with it, reviews of Neomide are only good for the antiseptic.
bill
Sure, that is not a fake? It creates a film that is cleaning the UV from the sun?
P.S. However, logs are crackling in any case, and even in the shade photo, I often spread. As my personal experience - two baths and two houses ...
