I think 28 or 26 or 24 are equally cracked, again, it depends on as correctly mentioned above, the properties of the particular wood from which it is taken each log, the quality of cutting, etc. In a wooden house can log some little crack, whereas neighboring logs simply break ... You need cuts carefully if there is a narrow slot (for example in the inner areas of the house do not need a wide one) when the groove 12 cm or more, a crack on the beam itself will necessary i.e. where and make this cut.
On the photo the groove is too narrow here, and the crack went where it is easier to get through, where the groove is wider there is the weakest it makes its way back to something like this.
PS: Why are you afraid of cracks? You can’t live without them anywhere, even in a well-known log house they will be obligatory.
And we have come up with, I am sorry that I am here you are new from Ukraine, so I can not give you a link to your branch. I'll copy and paste:
So, a summer 2009:
1. Unaesthetic appearance of the walls (cracks in the logs themselves) forced us to think what should we do with this good, and we began to experiment...At first, we studied an expensive American sealer. Felt this way and that, but realized that not we will not overpower it financially and we bought several generic sealants and decided to experiment with them, i.e for 3 months we have created critical conditions for experimental logs: freezer, a hot sun, a water, freezer again and so on for 3 months. I can tell you that all sealants overall spectrum passed these tests! Their only disadvantage was the color. Especially you can not pick up, well, firstly, you need to grind, and then seal.
Our guys come-builders, try and look at and offered another option. i.e we cut small beams, and we pasted into all the possible cracks in our logs, then everything is trimmed and polished.
