Опубликована: 30 окт 2012, 14:21
If you do not lose the time of shrinkage, i.e do not wait until the boards firmly stick to each other, then caulk easily with the wooden spades, just do them more . This is much easier than to perform feats. But, of course, if your house has not a full shrinkage, you can use timbers, but without a roof, but I call it to "plug the holes". There were so clever mates! They were going to make a primary caulking of a little house, trying to save on it. They did that job just with the wooden caulking. Only, if they do not have time to do the first part of the house until we collect a second, then later they threw that occupation as they could not score a tow in the slot, and the moss was hacked even by wooden tools. You can caulk a bath with timbers, maximum a one storied house. And you have a two storied house and beams 30 cm, to cover with a slate or a tile, then you couldn’t work normally even a week after the installation.
I have a couple of questions:
1) How long is a tow clogged and how to determine how much of it goes into the groove?
2) The tool as I understand is a common chisel?
3) How to determine the time of caulking to get between "the log house is already shrinked"?
