Опубликована: 31 окт 2012, 13:07
Тема: log home wiring ideas
Good afternoon! Now, it is my turn to do the wiring in a wooden house, of course, I want to make it hidden, as I want the aesthetics in the new home. I will sheathe the house with the imitation timbers along the guides, i.e. there will be a place for the wiring). I can’t search the forums how to make the wiring safest. I understand that it will be right but still. As I have a separate lot, then it is not necessary to pass the wiring.
And so, after collecting all the opinions, I want to do so:
1. An iron shield,
2. A VVGng wire, the usual sockets 2.5 to the light of a 1.5 square. Vending machines respectively 16 and 5 amps.
3. The wiring will ripple in the metal or black metal ripple in a PVC sheath ... By the way do not you think if we need a braid? Then the oxygen supply will be limited, of course, provided that all the ends of the wire were treated with the special sealant. Incidentally, I will caulk with a sealant anyway as there will no traction in a channel. The choice of the metal sleeve, based on the fact that it does not burn, of course, it can transfer the heat to the wall, but I do not think that it will be critical. Just a replace of wires in the metal sleeve is much easier than in plastic flutes.
4. I will fix a crimp to the wall with special ears. So, nothing will be hanging out.
5. Everything is soldered insulated and on top the insulation which shrinks when it is heated by a cigarette lighter. Sorry, I forgot the name.
6. All the twists in the outer box, or rather outside it will now only covers of those boxes), that is also aesthetically.
7. On power lines my own cables with their individual machines and a straighten line directly from the panel.
8. In general, I will try to use the twists to a minimum.
So, Did I miss something?
I will be glad your advice and recommendations, can someone say its word for ordinary plastic crimp. It is certainly much cheaper), Thanks!
1. An iron shield,
