Опубликована: 24 апр 2012, 12:13
So, where will it go?. Let's say it begins to accumulate in the outer layer, but near there is a fiber with a lower humidity. Fold two blotters - wet and dry. A humidity will be high. Imagine that you split the wall along many blotters. In the wall a humidity is not an average, of course, because there is a different temperature and a humidity at the ends, but a gradient is established. And as the vapor continues to flow into the wall, the "warm" end of gradient will start to rise (there is a place to evaporate), breaking the balance within.
Well, a thin capillary can’t be filled with water by a half, if the water is enough to fill it all. There are the foces of the surface tension of water (intermolecular interactions).
In fact, the evaporation, as I've said earlier, will continuously go on both ends, and it will replenish by the influx of new vapor, heating the air in the room, you are charging the same thermal energy of molecules and create the increased partial pressure, and sending to the wall. There, condensed, they will give this energy, and join in a capillary flow. This flow you will pull inward, giving the thermal energy of molecules on the surface of capillaries and allowing them to evaporate. And due to the forces of intermolecular interactions that the water has very strong, and you pull the molecules of following items of capillary.
By the way the water rises so from the earth against the forces of attraction due to the thermal energy of the sun.
