Опубликована: 30 июл 2012, 06:51
A vapor burns, but it is sandwiched between a drywall and an ecowool, first, the drywall should burn (what kind of plaster do you recommend, and how many layers?)
A fiberboard is not so environmentally friendly? A windscreen, too, must be thrust under the slab material, so as not to burn or not? What a smart vapor barrier do you recommend, a brand or a price, please? And if you take a sheathing on a top of5-cm slab basalt slam, to increase the fire safety? With regard to a ventilation, it seems to me you do not understand me at all, but I'm not going to prove it to you. I'm just telling you, I know it inside and out, and when I blogged about a device and a volume of air in the reality ... And I know who is and where. A concretization is needed, not less than the construction of walls. And finally, there is a speed control, as well as I wanted to set up.
