Опубликована: 26 июн 2012, 14:23
Yes, everything is fine! Never mind.
I just really do not know what you mean.
I perfectly understand your idea that the exhaled air goes away from the tenants in the exhaust ventilation almost mingling with the fresh supply air, and the necessary volumes can score. But in reality it is not. It is ideal to aspire to. But as every ideal, it is unattainable in practice. The polluted air is mixed with any supply air. In addition to a variety of convective flows is more diffuse. Here's your room 2 x 2, it is possible and achievable, where you're sitting at a table in the way of a fresh air and exhaust you behind your back. In addition to the standards of the volume, there are also standards for a multiplicity. If you still can find in five minutes, here and figure out what will be the concentration of CO2 in a small room with no ventilation 2 x 2 let in 3 hours, and the same thing with some ventilation of their choice. And so you will tell us. It will be very clear, why do you need a ventilation?
But what do you mean as a “breathing log house”? And a theme is so called.
