Опубликована: 31 янв 2013, 14:26
I will describe how you can collect yourself mosaic pictures from the glass mosaic. There are two basic techniques of assembly - Roman, and matrix assembly. Let's start with the matrix panels. First of all, the plot is the soul of any work, if the idea of a difficulty is not stopped. How the picture will look like in the mosaic can be found using the program, such as Pattern Maker – a simple program allows you to split the image for monochrome cubes. Matrix panels are mainly collected from mosaic 10 x 10 mm or 20 x 20mm. It is clear that the smaller the intricate mosaic pattern you can assemble, but it is much easier to buy mosaic 20 x 20 mm. Also the matrix itself is needed (cells of mosaic), you can make yourself or buy.
Next, the result of the Pattern Maker will be a picture is divided into blocks to scale, we can only move it into the matrix.
On a visible surface is glued the oracal, cards get their number and for that number they are placed on the site (for the mosaic there is a special glue, mainly sold in the same place where the mosaic is relatively cheap) after the glue is removed and the seams are grout (the grout is also sold in order stores).
