ideas for log home interiors
  • Среднее: 3.7 (3 голосов)
  • Опубликована: 17 дек 2012, 12:25
  • Автор: Summer
Summer
Тема: ideas for log home interiors
Please tell me how to paint interior doors made of MDF in the style of Provence? If someone has done this tell me please how to begin. I want to repair my old furniture ... It is understandable that you first need to remove an old paint, and how to apply the coating? How to do an artificially aged coating? Who does make it?
constructor
Тема: Re: ideas for log home interiors
A very bad picture, but I'll try to explain what was done with the door. There is, as far as I understand, one of the techniques used for aging cover or simulated aging. I'll describe both options, using available materials. One is acceptable and easy to perform.
We presume that all the doors of MDF, as a rule, already primed for painting. If not, then you should do
1. First, cover the door by the ground (not to be confused with the primer for the construction work).
The first option is the imitation of aging.
2. Paint the main door by the paint color ivory (by the roller with an acrylic paint).
3. Take acrylic paint (yellow gold), 3-5 cm flat brush dipped the brush into the paint, remove an excess paint on the edge of the bank and make a few strokes of cardboard until the brush will not nearly dry. A slight touch on the convex part of the panels, clearly in one direction applied by brush lines, creating the effect of translucent gold substrate under the shabby main white.
4. Apply the pattern you have in mind (by the pencil sketches, templates, an image, translated through the blueprint) with acrylic paints.
The second option is aging.
2. The places of aging cover (ideally with a gold leaf) are painted with "white gold."
3. Now cover the whole door acrylic ivory.
4. After drying, carefully, place the proposed aging, process abrasive side sponge for washing dishes. Until you achieve the desired result. You can, of course, use the sandpaper but it is better and more accurate when using the sponge.
5. Draw a picture.
6. Cover the door with a colorless acrylic lacquer. Because gilding is a foil of an alloy, mainly of copper and zinc, with time, it is oxidized by changing color. The varnish prevents the oxidation process.
I advise you the first option, because for the second one, some experience and knowledge of the material is needed. You can experiment on the small things; it would be not offensive if you do not get the desired result. Go ahead and you will get everything.
It would be simpler to describe in detail the whole process of work if you tell more specific what you want, what kind of colors?
Добавлено после 45 секунд:
In general, it is easy. There are several ways. Recently, choosing the simplest of them, I restored two old Viennese chairs.
The first step, of course, took off the old paint.
2. Then I primed chairs with a white paint, which, in general, is not always necessary.
3. Then I painted a desired color and covered chairs that turquoise (more contrasting colors usually look more effective. Everything depends on what you need to bind the color).
4. When the turquoise paint dried, I rubbed by a wax places where you would like to see serving turquoise and white paint again struck (again, you can give it a tone).
5. And when this layer is dry woolen cloth rubbed places waxed and if you want you can sand by the small emery paper.
6. Then I drew a flower and walked nacre. Then I covered chairs with lacquer again, water-based, as well as a paint.
7. In conclusion, were sewn soft pads under soft zones.
8. The result is in the pictures.
Summer
Like many people, I decided an independent painting of doors in the style of "Provence" at the lack of alternatives on the market at affordable prices. I'm trying to create a white door with elements made of old gilding, different variations on bars as I have never done it before.
I saw in the topic an old green door and I fell in love with it! I would like to make in this style my own home. A construction is now in full swing, I have even 1.5-2 years to repair and finish, so there is time to carefully prepare. Why use Provence style? I think that the interior is decorated in that style, looks very comfortable. I like bright colors, beam ceilings, natural materials, colorful furniture and curtains, all kinds of accessories. I offer to post pictures of the interior in the style of Provence, as well as a furniture, fabrics, wallpapers, etc.
It’s very interesting to see if someone made my own house or apartment in this style.
baltazar
Very nice style of Provence. But what you posted is very far away. "Not all that Provence that is white" I said the famous saying about the gold. The furniture in this style can be found in Moscow, but be prepared to prices, which are, personally, crap (though for the good things I am ready to pay, but the appetites of our furniture dealers are outrageous!). Look sites shops of "Interior Shop" and "The French things". There the focus is not on the furniture, but on the interior and household gadgets. Such furniture in the style of Provence can be found in the Grande and it will be produced in Malaysia! From the solid tropical wood, gray and white, in the old style - Yum!
And download the movie "A Good Year" with Russell Crowe and carefully, step right, review the home's interior, around which everything revolves. I say nothing about the garden - it's not for our latitude, but interior design can be borrowed.
In the time remaining before the finish, look for a good private joiner, Provence is the same country style, it is quite possible to do. A Provence style is a good solution for the second country home. The furniture of this style is really expensive, but you can search the Belarusian furniture (it is possible to paint) and forging is also possible, and to the state of 'Provence'' the interior can be finished by textiles, utensils and other details.
bill
I looked up your pictures. Can I make a few comments?
The Provence style is
1. A plaster on the walls. And not a wood and flowered wallpapers. But the wood is acceptable, but not in large quantities.
2. Wood for the furniture - OK. But either muted colors or dyed.
3. Color. White is acceptable, but not in large quantities. Increasingly used earth colors: ocher, terracotta, yellow. Even olive and lavender. Blue is used rarely and rather dim, gray-blue. In general, all the colors muted or faded.
4. Roses are no peculiar to Provence. From figures there are lavenders, olives and wheat. More chickens and roosters.
Although you shouldn’t probably fit all, not for the show!
If you are satisfied with just a "rustic" style, it is possible to use these English roses and Mediterranean striped blue and turquoise... Do not forget the sense of proportion and taste - and you will get everything!
Summer
Unfortunately. My kitchen will be done not so soon ... (The house is under construction ... but I plan everything in detail) And judging by the album you are also love this cute style in the interior!) So, I looked the Belarusian pine furniture, of course, it will fit perfectly into the design after appropriate refinement ... but how the pine will behave in the kitchen, for example? will it deform?
bill
It is correct that you are planning, and the main thing about Provence style not to overdo it, no need to copy thorough, a total look will tired faster than competent accents. A pine may shrink, a manager in one show room said that if you have a house for a seasonal residence, the best way is not to build from pine: a humidity, a temperature drop, etc., on the other hand I have in me log house a pine furniture and stools which are 70 years old and they are as new. Speaking of the kitchen in the style of Provence and a country style in general (Scandinavian, English cottage-style, Mediterranean) we have to consider appliances to match or at least not fall out of the general direction of the easiest to the oven, there are many different and worse with a sink and a refrigerator and a microwave oven does nothing (only the overhead panel in a retro style, cost more than the microwave). Some people manage to combine country and classic furniture with the modern equipment, but it is more difficult, you should really think, try and see the interiors. This may be well, but, I think, it gives a very clearly vector of the rest of the kitchen-filled with the murals, it will tie your hands in the choice of furniture and equipment, tiles. Choose options for the rest and if this print doesn’t argue, it will have the right to exist. And depending on the size of the room, in a small kitchen you will not "see" its place and space.
buldozer
The house for a permanent residence! And maybe when you order a factory furniture, ask how to handle it with an additional wood composition, preventing shrinkage? Or vice versa does not cover, and do so only in a raw form, and having picked up the order process the wood, and so there was no doubt.
bill
Copies of prints on botanical themes are gracious thing. Print out, and you can take a piece of paper not quite banal, but more complex which is sold in stores for children's art supply stores or hobby items. Then wet the paper by the used tea bag (wet) warm it in the sun or a battery to become cracked and finally old. It works very well for a classic style.
Summer
It seems to me it's not a "part of shrinkage" although I really imagine this compound, and that the wood should be properly and fairly dried before becoming furniture. Now we're talking about Provence style, but there are acceptable and welcome even minor flaws, this is not a death classy style. I think anything will happen with this furniture, solid wood furniture always breathes, it's even pleasant. Look up these old botanical engravings on the theme: some flowers, fruits, and vegetables. To enliven the interior. The size of the kitchen is suitable)). This will be a kitchen-dining room? I am about this:
Добавлено после 1 минута 20 секунд:
Thank you very much for a lot of great pictures. Details really are very important in this style. But, for example, I am very interesting to see the realization of this style in a private room or an apartment, or a house. What's on the floor, parquet, flooring or tiles? On the walls: plaster or wallpapers? Textiles: roses don’t fit?:-) What kind of furniture? How it all fits into the TV? The pictures are very like everything, but how to make this style in your home? And I was more worried about not clear embodiment of style (indeed, the exhibition is not), what will look tasteless. For example, my kitchen I do not see so.
baltazar
Firstly, what is stopping you realize? All posted pictures (not interiors), these are suggestions of Moscow online stores, you can order to see and relate to your capacities and desires. Secondly: Why do you think I have so many pictures? I am looking, revising many times, every time I pay attention to something new in the familiar interior. It is very hard to me, God has not given a spatial imagination, I can not draw and explain, I need a picture, but better actually see the item: wardrobe, chair, wallpapers. It will be also very interesting to see the actual interior (not only of Provence style), but on this forum shows the construction site. As for your questions: floor tiles, and even better a natural stone (see Petra antiqua), wooden boards, wall plaster, or wallpapers, but the textile flax, homemade lace. IMHO do not disappear, bring it here, and we will discuss it together.
Summer
I'm afraid of posting pictures, suddenly again, not on the subject) I posted a lot of pictures aside for myself in the subject. Simple interiors. I just see that you are interested in the topic, so you dare to ask, where can flicker interesting photos of interiors in this style. Not to copy anything for myself, but to have a clearer idea of the style. About my house I did not write, because the topic is of a great interest to many people, and I do not wish that it was limited to only by my housing). Before repairs we have at least one year, if not more, a brick box is ready now + a roof with no windows. The home for permanent residence in the country, in a lived-in village with 2 floors, a kitchen and a dining room – 20 m2, a living room 25 m2. The main thing that I would like to make it cozy! Our family - my husband and two boys of 5 and 13 years.
The interiors are still needed to be adopted)). This will be your reading of Provence. Yeah, a kitchen should be looked at the classics (a solid wood with a wood structure can be painted) and the TV does not fit in no time and that it should be hide in a closet or taken for granted).
bill
I make conclusions that this style can be quite economical to realize, but is still realized (which I personally plan), but still it seems to me that the whole house in the same style will be a little heavy. For a seasonal residence it can not be so, but for a constant living it is obliging ... But the kitchen and a "Provence" style, in my opinion, things are very harmonious!
buldozer
Yes, I think the Provence style is good for cuisine, kitchen-living room, as now it is more often, but if you like Provence you can hardly make the remaining space in a modern style, just when it comes to Provence often there is a mean of the European country or light classy or retro. There is no need to measure the style, and then the interior will be heavy. Look up the photos of the European interiors of country houses, a mixture of styles, different textures, furniture of different years, but it is quite interesting work...
Summer
I want to discuss living rooms, combined with the kitchen of Provence ... As a rule they do not have a strict separation of private zone and they exist in a common space. If desired, it may be the Provence style, but I think it is better to restrict the details of style, not dipping into it with head.
baltazar
I like the painted wood, Euro prestige shop have a kitchen called Terra, it can be colored in any color, look at it, you can enjoy the "air of Provence". I know it is expensive. You can see an interior shop, it is also nice and expensive, but the one-two item can be selected in order to match the style statement)), I think the Provence style is nothing there. And even if there would be something like this (as in the photo), I do not mind. Children’s room on the second floor, each one has it own, so it will have no effect to a common "design concept" as I think. I think it is important, for example in my house to somehow combine the style: entrance hall, dining room, living room, staircase hall and a small corridor on the second floor. Well, it will be great! In this exciting style there is a play of ideas for decorating. Look great aged decorative paintings on a plaster, wrought-iron furniture, painted antique wooden furniture. With all three points I can offer an expert piece of advice!
bill
How to design children’s rooms we will decide with the hosts of rooms). I think the Provence style is nothing there. And even if there would be something like this (as in the photo), I do not mind. Children’s room on the second floor, each one has it own, so it will have no effect to a common "design concept" as I think. I think it is important, for example in my house to somehow combine the style: entrance hall, dining room, living room, staircase hall and a small corridor on the second floor. Well, it will be great!
Summer
I do not agree with the expressed categorically above that roses are knocked out of the Provence style. Any flowers are the Provence style, especially roses, sunflowers and lavender, how to live without it ... only it should be gentle without any spots. After all, in fact the Provence style is just a country, French, or a rustic style. Forging, pastels, aging, patina and craquelure, any brush, chests, benches, vases, watering cans, jugs, ottomans, chair covers and other lovely things. I love the Provence style, I am planning to furnish my house in the same style ...
So far, the walls are painted in pale green and terracotta (2 rooms), windows and ceiling are white ...I am going to restore the old chest in the style of Provence ... and doors are painted. We'll see what happens. The topic started with painting of doors. I read a lot of forums, the beginning is all the same: an acrylic paint. But what kind of paint? Water-based? Where to see it: in DIY stores or shops for handicrafts? Tell me, please! I’d like to do it, but I'm afraid to spoil ...
So. An acrylic paint is an acrylic paint. It says so. There are nitro paint or oil based, there is alkyd and acrylic is. It is diluted with water. A tikkurila have acrylate, I think, it is also suitable. There is a lot of acrylic paints from each manufacturer. The acrylic paint is more artistic or decorating, they are along with the acrylic primer sold in art stores, even in parts of the stationery. In a small jar, like a gouache. On the basic acrylic paint can be applied the pattern, ornament and other. The acrylic paint should be whole acrylic and ground, the main, and the drawing. An acrylic lacquer, too, or else a single layer on the other will not stay. That's is a wisdom.
baltazar
We built a house, I want to finish it the style of Provence, I made a large collection of photos of interiors. But proceeded to the furnish I had some practical issues. Beams and columns in brown I will dye with an oil or a stain. But the color of walls and floor linings in white and translucent in white solid color? I have already broken my head, looked up the whole forum, then Yandex. Give me a prompt, please. I promise to post a photo report.
How to restore doors? The problem is as follows. The door box in the bathroom and a toilet is single, its size is strange. If you change the door, I'm afraid that a half of it will crash. Therefore, I want to just take off the door and do something they bring to mind. Can you advise something? I don’t want to use an adhesive film. A painting is not very desirable.
expert
Option 1:
To stick to them PVC panels, then to stick an adhesive convex molding on top, it is better under panels, you can take from the car (which is in our old car is glued on the side of beauty - it would be better to stay).
Option 2:
To clean with a cloth, to paint, and to glue the foam edge, you get kind of wood with panels, fashionable and ink drawing of the tree.
