ideas for log home interiors
  • Среднее: 3.7 (3 голосов)
  • Опубликована: 17 дек 2012, 12:25
  • Автор: Summer
Summer
Тема: Re: ideas for log home interiors
As for the cost of work, I draw sketches myself, collect puzzles and under my supervision an installer installs and grouts, so I always try to find a compromise with the customers, the cost depends on the complexity of the material used, it is not necessarily to do a hard work, it is possible for example to the bathroom develop a decorative border, which will be a decoration of the interior walls or to use a matrix technique, there are so many options. I make a mosaic from marble, glass mosaic of the Italian and Chinese production.
constructor
It's obvious that you are a professional. Can I know where did you learn it? Your work is impressed! I am ill with a mosaic, so there a lot of questions. For a week I have sit in various forums, I looked gallery of finished works, but yours, especially the "carpet" in the hallway, and flowers on the front, they are over some! Another question: where do you buy a smalt? in the construction markets? Do you have an experience of on-line order? Thank you in advance for your answers.
Summer
Thank you, I studied at the art school of Kalinin, and then MGHPU of Stroganov. I started making a design, a mosaic while studying at the company firstly, and then independently in 2007. I buy a glass mosaic from companies that sell tiles (on the principle that a shop not far from the house) and a warehouse nearby, I have never ordered from the internet, I do not buy in the markets, in terms of smalt which in pancakes, it is ordered very rarely as it is very expensive to obtain. If you are interested what companies to buy in, I can write you in PM. I chop in pieces the correct size and shape, a tile 2 by 2 cm for 4, 6 or 9 parts, if necessary I make them smaller, the same is the smalt in pancakes and a marble, pricked on the necessary pieces to do this if the artistic mosaic. If you do with a matrix technique, the finished squares are taken 1 by 1 cm and obtained like a pixel, it is easier and cheaper. As for the cost, it depends on the technique of execution tiles that come in two forms in an art or a matrix technique (the figure consists of squares, as pixels) and of the complexity of drawing. It is the most expensive and artistic technique, but it can do a very simple picture of two colors, and can be complex panels. Price dispersion on art technique is very large.
According to the same matrix technology, you can dial an extension, mix color, a simple two-color panels with geometric patterns or more complex, or very complex, also include the value of the material from which it is made of. Some samples. The cost for a matrix technique without a material cost (the material cost will be included when the customer says what kind of tiles he want - the Chinese or the Italian, and after selecting colors as colors are different) and an installation, the price includes a delivery and a mixture of sketches, 500 per m2, stretching from 900 per m2, a panel depends on a complexity of from 2,000 rubles, an approximate price. As for the cost of artistic mosaics, I will write in PM.
bill
How long have you done this finish? When I bought the tile for the lodge, I was told by sellers not to put on the street or the loggia tiles for the interior use, as freezing it will feel unwell. It absorbs moisture more than the outer brickwork and can give a lot of cracks in the cold weather. Have your finishing passed the winter?
bill
expert
Here is a little-talk about mosaic. I was busy with it. It is really quite difficult to cut tiles by squares. For this deal, I was cutting tiles by strips 2 cm with a tile saw it was real. And then I picked the right size of square or rectangle. They get pretty big but with a tile saw become smaller. Then these pieces can be made smaller but it is very time-consuming. In fact, professionals do not use tiles (except noted cases. And the mosaic made of it is too rough and simple). It is very thick. They "cut" mosaic tiles that have the size 2 * 2 or smaller. They are thin and very well and smoothly handled by tongs. It is quite expensive, of course, to buy the mosaic. So, I used a custom tile like everyone else. And I banged it arbitrarily. Only when covered with pretty big volume, for example, curtains, I used squares. That it is quite time-consuming. Personally, I have only recently discovered the cutters with two cutting rollers, which are usually used by stained-glass window makers. The case has gone much faster, and the process is like cutting, rather than chipping.
The mosaic 2 x 2 is not very suitable for outdoor products, but in all other respects, this is a great range of colors, and of course the great artistic opportunities.
Summer
I decided to make a bench made of an old concrete sill and decorate it with mosaic tiles. I have already laid some part of the picture on a wooden board, not thinking about the time when I would transfer it to the bench. Read the whole topic there was the advice to fix pieces by tape. But I think it is suitable for small fragments. And I have a length of about a meter out, I'm afraid that the tile is too heavy, and there is no duct tape to hold. Maybe someone has an idea how to move the puzzle in place?
There is a little thought to turn the entire mosaic pave inside out and apply a tile adhesive. After curing the adhesive to transfer the resulting mosaic plates on the bench. True, I do not know what will be a thickness to fill one side, as not be broken off, while I move, on the other hand, it is not too heavy. Alas, no more other thoughts. Can someone tell me what to do? The grout was very ordinary; I had some remnants from repairs. The table was not used as a dining table, this was a dressing table.
For the dining table, I think it is better to use the whole of a small format tile or a finished mosaic, and as a grout you should, probably, use the one that is designed for bathrooms, it has to withstand the daily procedures from a food residue.
Now, I try to find a picture of another table, plus there is a grout for the bathroom.
baltazar
I have a table of the same type. Heavy wooden legs, a table top 90/90 from plywood framed with a wooden edging about 1.5 cm. Sliding halves under the table (an unfolded table 90/180). A plywood on the main table top stratified on one side. Here, I think it to remove and choose between three options.
1. Economical – to buy the new plywood and paste, varnish.
2. Expensive - to give hardened glass under it and make a collage or herbarium.
3. Make a mosaic from tiles.
A dining table, and so should be indifferent to the aggressive media and influences.
Lower - sliding parts of the worktop in good condition, and leave them under the varnish only with the other parts.
May be there will be other ideas or suggestions, I will be happy to read them.
constructor
If you make the mosaic, are you not afraid of that the plates will rumble on the tile, once it is the dining table? I have no dining tables, but occasionally, when you put on the table, such as a cup, it seems that it will break. Although, there are many examples where the countertops in kitchens made of tiles and it is OK. And you can swipe special napkins at lunch on the table.
I would choose your first economical option. I would replace the plywood, dyed the table in interior color (most likely with a translucent paint to see the texture) and I would cover the paint. He even Unfolded will look unified fabric.
But here, of course, you choose what you want. After all, you should not only be the result of having fun, but also on the process of "remaking".
bill
Last year I started to make a mosaic for the garden fireplace. It was a bit of a curve-oblique, so I wanted to make it prettier. This summer, I climbed up on the tube. Well, I made a dragonfly and a butterfly from one end. It remains to complete the facade; I can’t still find a bar of a desired color. Frankly, I have made it for a long time. The flowers probably took 5.7 days, but I'm just working slowly. A fire has not been completed yet, a lot of work remains. I want to portray on a facade a salamander in flames; it's the spirit of fire. While I am picking up tiles of matching colors, but so far have no idea how I was going to do. What to make at the bottom of fire I haven’t decided yet. I thought about trees ... Maybe someone will have other ideas?
baltazar
I found on the Internet different photos of salamanders; I cut and moved the circuit on a piece of plywood where I am going to lay out the whole picture. I had the remains of black tiles with golden streaks, so, I decided not to bother with speckles and to lay salamanders entirely from it. Alas, this whole work has stalled. I have no artistic talents or skills, so I have no idea how to draw the fire. I have been searching the internet some schematic drawings, but I found nothing appropriate. And to make from photos, alas, it does not work. I broke a few tiles of various colors, and laid out in such a way and that is nonsense. Try to look for more ...
buldozer
I love this forum; I read it all the time. And your art works inspired me to make my own idea. I decided to mosaic walls of my house. The work with a ladybug is my second, and a mosaic with a sun and a flower- third one. I cut tiles with something was at hand – a glass cutter, it takes a very long time, and the glass cutter was broken all the time, and the background of two panels of the bat I made from broken tiles, but I just did not like the end the method because there was a lot of waste. The next step, of course, is to buy a tile saw. So, I advise you to be inspired, too! It is beautiful and not very difficult. And so nice to do even simple, but it still works. Good luck!
Summer
I hope the next time it will be even better). I would like to have many pictures as I am short of ideas of ornaments and patterns. I can’t draw myself. (And for the question. We personally did so: first, we plastered the wall, then; I waited for its drying, then primed, too, until dry, and then we trucked the moisture resistant glue (we had a firm ANSERGLOB) and then another grout for wet locations. I think it will be also nice for the bath.
expert
Does someone interested in? Here, how the mosaic is laid down on a concrete, plastered, painted, glass, plastic surface. The smaller the tiles (4-5mm in width, a length max. 30mm), the better. The glue is anyone that glues tiles and joints that are not more than 0.5 widths of tiles are filled with putty, for example, cement 1:3 (I always worked with the paste, I put the photos of a sewer and irrigation wells). First, I draw the picture, then I glue the broken tiles, then the seams are filled with mastic and a final stage – we gently wipe the display until the drawing. It is possible to do otherwise, so, go ahead and experiment!
Summer
I made it so. I only gather fragments of 60 to 60 gathered at the table. Then they tape the tape, flip, coated with glue, I immediately smeared the wall and pasted. Normal tile glue. The next day I filmed the tape, wiped with a damp cloth and cleaned with a conventional grout adding colors. A free space on the wall was laid out in the form of algae and was laid by blue tiles. Mosaic splits and the theory is not without fears. True, after laying panels the joints rubbed with a special grout and for 15 years I hadn’t not any case (at least the information about it) about any cut or any discomfort. Personally, I would advise you to lay down on the floor as the product of the matrix assembly and beautiful Roman art on the walls of harm's way.
bill
There are myths about mosaic on the floor. A mosaic from glass (since forever) but the glass used to be considered fragile and slick. To break the "cube" you can with a hammer and you can’t get for the first time. The mosaic is from glass and it is slippery but it is small and between the mosaics there jammed joints that does not allow for glide it easily, at least not more than the usual slippery tiles or parquet. And the mosaic is not virtually erased even if there is a caravan on your road but there are series of pearl mosaic in a certain upper layer can be erased so, carefully choose the "cube" on both sides should be the same.
expert
If you have quality tiles, so it can stand temperature changes (we are now + 35, and in the winter up to - 40), and rains. I one tile failed, after the winter a top layer tears. Well, that it was quite small, a small piece crushed, I used it in one place. The rest of tile have lasted for two or three winters, while everything is OK, nothing shabby, not fallen off. What makes sense to take a ceramic tile, and then to beat it and to worry how much do live ceramics and the product made of it?
Glass mosaic costs $ 10 less, it doesn’t absorb the moisture but it is more convenient to work and a very different view at least not like finishing of buses in Soviet times ...
buldozer
Let me agree with you now. There are real masterpieces in this topic, but basically, I personally, admire by the work, rather than an aesthetic pleasure. Besides, I am embarrassed by the fact that such a monumental mosaic eventually tired and the author grows up his work and then, the early works will irritate your imperfections, and there will be a pity to dismantle the expended labor.
I'm also going to make a "mosaic" of the broken tiles for a blind area. True, the mosaic will be conditional and the color of tiles will be white, beige and gray, and the fragments form is rectangular square (I will just cut off the uneven chips).
constructor
I looked at works of the forum and I wanted to make a lizard from mosaic to put a blind area. The sketch was found but that was something confused me, now I understand and I fully agree. But that's where to look for this glass mosaic? I saw creative kits, but they are expensive and there a few marbles themselves.
expert
Where are you from? In Ukraine, almost in any store where tiles are sold and mosaics can be taken. Mainly various mixes least one-color used to finish pools, saunas, bathrooms, just in the interior. There are specialized companies (like mine) where there is a large range of materials and you can order ready-made products.
