Because in every room in the attic were obtained 3 windows. Initially, I thought about it. It was light. Then, some people told that the bedrooms the light was not necessarily, but the windows in the attic:
- One window is on the south. in summer it will be very hot.
- The second window is on the north. in winter we lose an excess heat.
this is not good.
I estimated 0.5 sq.m. of the dormer in the roof + 0.2 sq.m. loopholes in the window for the room of 9 sqm, it will be enough if it was a bedroom.
According to the norms of area, such glazing is enough for 0.5 * 10 0.2 * 8 = 6.6 sq.m.
On the other hand, a large blank wall in the number of 2 pieces are not quite beautiful, though you can use the siding in order to avoid a monotonous ...
Maybe I'm wrong, frankly, I haven’t fully decided yet. The decision is so...
Should be ready for the installation on January 10. The door is custom-made, a heavily armored, not well-known brands. Inside the door is the IDF under the film like a wood. Outside the door there is a granite paint of a rotten cherry with black wrought elements + bronze. Bronze findings. I do not know how it will be, but the outside design I made myself and that’s I worry a little bit whether the proportions and the color were good ... It remains an exciting 3 weeks out ...
Well, first, if visit in winter ... the dormer windows are always covered under the snow, sometimes with an ice. It's one thing just to knock off the snow, and another thing to clean off before the normal light transmission. After all, I would definitely not to give up of the gable windows. And from the excessive heat in summer I would use thick curtains.
