He drew the power distribution scheme of the house. Finally, we have built the walls of the bathroom in the attic. We made the floor in the attic above the attic and the crack under the door to the attic.
Boards are without soaking. I would soak in place. That was a string of days off, but really it was not a weekend.
We have done a considerable amount of work for two weeks.
1. We made a infilling between adjusting posts.
2. We baited the grids
3. We impregnated timbers on a sheathing under the siding.
4. We trimmed two of three horizontal eaves.
5. We excised from the DSP the floor for two bathrooms (not yet laid).
6. We paved the water in the garden.
7. We worked at the garden and the kitchen garden.
The infilling between adjusting posts.
We made the infilling between adjusting posts from sheets of DSP 16mm.
The lathing from timbers of 50 x 100-150.
We fixed the lathing to the grillage with the bolts 10 * 120. And to the crowns with the bolts 10*100.
Under the bolt heads we drilled a hiding hole. The lathing from the concrete and from the DSP we laid with a ruberoid of 1.5 mm thick.
DSP to the sheathing was fastened with screws of 5*60 or 5*50.
The places overlaped with DSP, we protected by the small galvanized metal mesh.
The ventilation openings were temporarily closed by the grids, so that cats do not climb.
Under the sheets of DSP and the lathings the ground was selected by 15 cm in deep and filled with a sand to protect against a possible (but almost unbelievable) heave in winter.
DSP comes to the sand and the ends of beams and purlins are hanging over the sand at 10-12 cm.
Such a hanging design.
In fact, the rigidityis exellent.
I quite liked the DSP as a material.
Now, you can put a tile on the elasticity glue.
The plumbing in the garden was laid by the tube of 25 mm under the track at a depth of 15 cm.
The gids were only secured with an internal mounting to the frame posts.
Under the tie-plates there are stil laying temporary gaskets from the boards.
Before the laying of the wind barrier, a sheathing and a siding, the grids will be removed, placed on the right place. The sheathing on the sides of the windows will be double-layer (board-plachtina, grid-board). The boards of 25 mm. The thickness of the sheathing will be 50 mm.
The trimming of the overhangs.
I checked in use the tool for punching locks in the back rows to lock on the finish bars (Snap Lock Punch). A luxurious piece. I made locks at the top of the bevel and snap them into the finish profile nailed in advance by a drip. Snapped and then nailed it from the bottom. I have a J fascia. The same locks were made in the last bracket of the soffit and locked its edge in a light tightness, and a J-profile, which is inserted into the corner.
I worked at the place where three external angles would connect in 3 dimensions at one point. I had to exert a strong spatial thinking. I figured out!.
I made the joining facets (laps) in a wrong direction, and, now, they are seen a little bit from the yard, but it's OK. But there are overlaps of the prevailing wind it seems to be as recommended.
That's what happened.
I trimmed he top overhang.
I began mounting with screws, as last time I was tied to beat nails under the overhang.
Screws were taken with a washer 4.2 x19, their head is 8 mm in diameter.
I renovated by the home way rechargeable batteries for the old drill Bosch 1200, and here it is a luck - the work goes 3 times faster. Only, you should manage to twist.
By the way, with the batteries there is an intresting story. The new one from “Bosch” costs about 80 USD, and a replacement of batteries for new ones costs 28 USD. If you purchase batteries sparately, they cost an average $ 2 per piece. If you solder them with one band, the issue price is only $ 20. I have collected one unit from the old cans and the second one was gave to the masters, and it was rewired and was in the ranks.
Meanwhile, we collected the first harvest of radish.
We planted strawberries. And then we planted a winter apple and a tomato plantation from a cut grass from the lawn. We are getting ready for a massive attack on the siding!.
