The lake house in the country.
  • Среднее: 1.0 (3 голосов)
  • Опубликована: 17 дек 2011, 18:41
  • Автор: constructor
bill
Тема: Re: The lake house in the country.
Yes of course, you can!!. I have the same staircase in my old country house, just 5 cm narrower.. The third step from the bottom and the fourth step from the top level are straight. It runs normaly. Though, of course I would remade that ladder for a permanent residence.
constructor
So, I tend to leave everything as it is. But you can think a little more on this topic. In any case, thanks!.
buldozer
I remembered the cottage house of my parents. They have roughly the same (the ladder a little narrower). In principle, you can carefully walk. They only have a playground swing. If other options don't fit, ypu can use it for a suburban home, it’s OK!!
constructor
Taking into account the commentaries above, I added one more step in order to reduce the "angle of attack" of stairs. Also, I twisted the configuration a little.
There are these two options.
I do not know whether I can shove this construction to an existing building. I will measure everything at the weekend.
I think these variants will be a little bit more comfortable?.
The option number 2:
baltazar
To cut out and to trim such staircase is not easily. It’s better to buy the new one?.
Haven’t you thought at the expense of ready-made ladders as a "goose step"?.
Summer
We are building ourselves in order to suffer. As for me I like to make stairs by myself!. And the price for finished stairs is considerable, but if it is low, then you will receive a bad product, rather than a ladder.
Thank you, I'd better do it myself somehow!.
P.S: Then it is simply to order the whole dasha to build!. or you will be tired of building!.
Yes, just I do not want to do it, because you will get not what you want!.
bill
Well, I was also not allowed by finance - and I myself made a ladder out of 4 boards of 150 * 50 * 6000 mm and screws. And it was interesting - you're right, and my wife helped me, and it was interesting. Of course a lot cheaper than buying, but I did only three steps on the turn, but you have 3 right steps.
If you do it yourself, then do!. Once you are able to make a "goose step", then make it, the angle of stairs attack try to do wider...
From all options I proposed the third one.
P.S. I did not propose to abandon your own forces, do not you think. My house, I will plan to build myself.
constructor
The ladder has dismissed!.
After two weeks of rest in the South!! Let’s back to work!.
I began collecting the automatic electrical and with the SMS-control via a controller (PLC Unitronics Jazz). The management program has already written!. Now, you need to gather everything, set the object and run!. The truth that not the whole wiring is done, but it does not matter, for one living room you can do the whole thing. The point seems to be simple enough, but it is time consuming, especially, since I gather virtually the first plate from zero in my life!. Yes, and I want to do carefully, then it was possible to find out in a couple of years...
And most importantly, we began warming and then cold night already!
Incidentally, there is the question wheher who came across?.
How to insulate a posting under the vapor barrier into the room (the place from the latest picture)?. Are there any tricks?. And then there is a gap there!.
expert
And how the SMS management is in use and for what?. What is started using SMS?. :mrgreen:
constructor
Thanks to the SMS you can switch on and off the individual contours of electric heating. Taking into account that this is a dasha, It is very comfortable to prepare the house in winter for the arrival but not arrive until it is heated and freeze!. I have 3 units:
1. The first floor.
2. The second floor, a north room
3. The second floor, a south room.
Depending on the amount of traveling, we will heat the necessary rooms.
You can query the current temperature in the house, in order to be informed.
So, there are plenty of nuances associated with alarm, security, lighting, that are not in detail.
My brother and I will download the fridge with a beer before leaving in summer time. And, then before we arrive in advance hanks to SMS we will swich it!.
expert
- This is not a dasha, but a resident house for a permanent residence, there is enough money, I have read from cover to cover almost 4 hours, do you have questions?. How much material did it take?.
constructor
Ohh. A lot of materials!. (Sorry, as a question as an answer ). Thanks for the compliments!.
constructor
I gnawed badly the crust, or you didn’t finish it and here's a hint: For the whole building we bought 24 cubes of wood.
3 cubes of curved and bent wood left.
2 - 2,5 cubes are still remaining good.
Total: about 18-19 cubes.
P.S. The answer is not exhaustive - it is a stimulus for further research.
bill
- Do you mean the aluminum tape?. Because the films, that I glue between by a bilateral butyl rubber tape of a type K2. Like this (lower black):
buldozer
Well, maybe it glues well the films together, but to the structure I have a doubt. From the wood It will just fall off. I pasted such soft foam to the furniture panel. It falls off. And not from a foam rubber but from the wood.
constructor
Well, I do not know, in winter whrn it was 10 degrees below zeri, I set the films to the wood. (they have a rubber band-butyl), and everything is held very well. But I have not a joint wood, but a furniture board, it is very smooth...
Although I've warmed them by a foehn. It is a vapor barrier.
And there is the same one waterproofing under the shade outside.
Summer
////For the whole building we bought 24 cubes of wood.
Total: about 18-19 cubes.///
You spent a lot of materals. It would be easier and faster to build the house from logs?.
baltazar
Maybe, but I consciously built a framehouse. Although there are not only walls, but a foundation and a roof. And we should count all together, not piecemeal.
bill
I join you. I do not always like that, in the sense of a carefulness, and when it turns out, I am pleased with myself as an elephant, because my hands are not from "the place". And constructor in this case is a role model!!.
P.S. I would like to ask how is it a soaked floor?. Everything has dried up, is there any problem?.
constructor
Thanks for the compliments, I am straight embarrassed!. With the floor it is OK. Everything is dry. Where it was very damp, I nailed the OSB bottom up, so it dried better. Oh, and I wrote... A few more pictures from the history of the shield.
Almost everything has already cross-connected.
There is no only a 12V power supply for the diode illumination and a twilight relay. They have the operational testing with measurements of consumption in real combat conditions. Finally, I set the flap in place.
I connected a lighting and a heating circuit in the insulated room.
Then I connect the antenna to the modem. Now, everything works. We are remotely monitoring the temperature regime.
A few photos: :arrow:
Вернуться в «Timber houses from Russia information and feedback»
