As for the aesthetics, agree, but the practicality of a wooden stairs in the village with heavy traffic is too weak. Whether cover them or not, a sand, a soil and a dirt will quickly lead them to the wretched state, or even killed.
And so, on a concrete I will put the same tile as on the terrace and everything will be very practical.
The view will be stable and a clean up easier!.
The rain flooded over the weekend.
I had to hurry to sew the north wall with a Tyvek, because the wind blew the water into the house through cracks cladding boards. We had scooped for an hour ... I trimmed with a ladder during a pouring rain and a very strong wind. While it was rainnig, I began to make an entry. I held the lighting on the terrace and hung a temporary lighting. I put the time switches.
As a permanent yar hasn’t being yet, I leave the metal hose and cables with a reserve for a future switching. In the intervals of the rain, I set its drain on the southern wall. whether the wind will change or not. The next time I will trim with a Tyvek and the south wall, thanks god the outflow is already there and you can trim. I went down to the cellar there is a small moisture, the air temperature is 13 degrees below zero. This is the fully open channels of the airing.
In the underground it is dry and comfortable. Everything is ventilated. A sand is dry as a gunpowder.
But on the first floor you have to remove the CAP from the floor. Because under the OSB there is a film, and when it stood open, through the gaps at the junctions of OSB, the water got there. I drilled a hole and inserted a tube, then drained, like a gasoline is drained from the tank. From one cell I pumped 4 liters of water. This is very bad!.
I will cut along the walls and remove the OSB, then dry everytning and trim again.
Here's a drawback of the method of "platform" with a mineral wool. I didn’t think, when I heated the floor, it was necessary to lay an extruder there, or to insulate the bottom after the roof and the wall trimming, but I deliberately did not do it because it was sooooo difficult. Now, I have some troubles.
After these procedures I will lay everywhere on the ground floor the OSB boards DSP 12 mm. Then I will seal all joints with a sand and the Giperdesmo. And on top of the SPC I will put tiles. On the first floor will be only tiles!.
And some words about farming and gardening:
Cherries ripened. The rain was at first for the common good, but then was delayed, so, the problems will be able to occur. Last strawberries are roting.
Thanks God the area is open from all sides and everything is aired, but otherwise, I'm afraid everything would rot.
Tomatoes were saved by the fact that before the rains we have processed them with Ridomil.
At the weekend Kvadris will wait for them, definitely!. While it rained, I was engaged in every small things and a wiring in the house. Meanwhile, in the garden: apricots ripen. We work hard the fourth day.
I leased the forest. We are sheathing the southern facade.
Actually, the battle for the southern façade: a horizontal coffee bar I will expand up to the strip of siding, so, that its top was at the top of the façade from the garden, and I did not finish when I was trimming. Finally, we finished the facade, and then we sheathed the terrace along the imitation of timbers.
There is no sens to write a lot about it, here are the final pics. The terrace:
(Although even without a varnish, and it covered only with a Pinotex Base).
Next, it will be a Pinotex Classic, and the Tikkurilla Unica Super.
There will not be a tinting, a pine will give a necessary tinting over time, even under UV-filters of Tikurily.
It seems like that, but there are stairs (the steps), without which you can’t put all the drains on the plinth of terrace and without drains you can’t lay a tile, but it is highly desirable to make it. And to make stairs (steps), we need to plen the area before the house, to make the correct gravity layers for winter, so that the water will not come to the house, we have the same slope ...
But, we should to warming up the cold at least one room to make where to live, or then the stove in an old house will just be broken and we will not be able to warm the house with a simple lubricant heater!.
A lot of plans!!, as always. How to do everything?!
lease or sell the second head or a pair of right hands!. Only skillful!
