The lake house in the country.
  • Среднее: 1.0 (3 голосов)
  • Опубликована: 17 дек 2011, 18:41
  • Автор: constructor
expert
Тема: Re: The lake house in the country.
Do you have a kind of wiring of this miracle?.
It is so hard to believe that such person has collected that far from the electrician.
constructor
LOL!!. The man is not quite far away, he studied at the university, and has a high technical education on "Software of automated control systems." In other words he is a programmer.
He learnt electrical circuits. A principal scheme doesn’t exist in nature, there is such scheme... It was developed by me and I assembled the structure according to it.
Summer
A beautifully assembled shield. As the eye is pleased. Do not forget to hang tags, and to sign automatics, or then eventually it will be forgotten.
baltazar
You must have labels!. Now, I am not sure without notes and I can not remember where to swich. In the complete shield there are wonderful self-adhesive labels, and I will use them here, just a little later. I haven’t enough time to make at once.
buldozer
The only question is how to carry out a waterproofing of a masonry cellar?. Or there is always dry, just the drainage that you made was 1.5 meter above your cellar, as if it is not been as a drainage.
bill
Sorry, I re-read 3 times, about the drainage but I did not understand...
A waterproofing is a daub along the masonry, but in general we have a very good soil, the water "flies" as the sand and doesn’t prop up the wall. Plus, the natural inclination, plus there will be done a drainage system around the house, the foundation needs to be protected from the water!.
buldozer
Just, you have on your report one of the photos there was depicted a drain covered with a brick fight or anything like that, that was dug next to the foundation. In a previous post I mentioned that your cellar is deeper than the drainage approximately of 1.5 meters, and will not be a cellar in this case act as a drainage, accumulating the water in itself, passing through the brickwork?. And a waterproofing as I've seen is on top?.
constructor
A waterproofing is done along the walls and on top!.
Here are pictures where it is seen very well.
We experienced inclusion of heating by SMS.
While instead of electric convectors I use an oil heater of 700 watts. I use it in the insulated area of 10 square meters room.
At the exit to the country, I sent a text message.
When I had arrived, and the house was nice and warm!. It is super!!. Over the weekend, except for the "meeting on the Elbe" with old friends, I was engaged in posting on second floor. The number of "trunks" begins to shake my imagination!. And this is not the limit!.
There is the first piece of a fine finish, the floor in the room on the first floor.
I do not remember whether he wrote it before, on the entire first floor, it was decided to lay tiles on the floor, because of the dasha, the dirt, etc.
The process goes on.
On the subfloor of OSB I laid a vapor barrier.
Then I set an izolon (a polyethylene foam), to compensate for slight irregularities. It will damp an impact noise.
On the izolon layer I packed asbestos-cement plates (a flat slate), 8 mm of thickness. Seams of slate were treated with a sealant.
Further, this surface was primed with Ceresit CT 17.
Well, and then I laid tiles on the adhesive called Ceresit CM 117 with the addition of emulsion BauGut to improve an adhesion and a ductility of the adhesive layer.
Stitches were embroidered with a grout called Ceresit CE 33 of a super chocolate color.
When I were embroidering, I was eager to eat that chocolate!!.
Here's a pie that turned out, but this the floor.
Although, as always, I saved little things, and I took the only one spare tile. And I managed, in a dull, to spoil two tiles...
Well, I have to buy one (and two tiles in reserve).
Here's a convector that I bought of 1 kW. For 10 sqm, I think that will be enough. In general, I would like 2 of 0.75 kW, but none was available. When they will be, I will take 2 units of 0.75 kW (or 1 - 0.5 kW and 1 - 0.75 kW, depending on the results ofa kilovoltammeter) in this room, and this one goes to the kitchen there will be a large area. To it in a couple will go at 0.5 kW or 0.75 kW.
Wow ... such terrible thing!!. And the bracket for the antenna, was finally established. TV will be soon at the new home!. Well, a lot of things I have done, little things!! I have almost finished the wiring for a complete external lighting!.
It there will be eight diode lamps of 3 watts for a year, I will pay for the electricity up to 40 hryvnia (U.S. $ 5) per year (at a current rate). I think I will not be a bankrupt!.
buldozer
And the antenna will disappear in the spring after the snow as you know. In short, my friend, install the snow detainers!. Porcelain tiles on the floor, of course, are good, but only in the presence of a warm floor. And in summer and in winter it is not comme il faut!!. Tiles are only in the ground floor.
On the ground floor you will not be barefooted - it's a dasha!.
On the fist floor will be a laminated floor. Gentlemen, do not complicate things!.
The principle of simplicity is clean!. A country house, a dasha ...
The angle of slope of the roof above the antenna is 23 degrees.
The snow does not go from the bitum, it melts and runs away ... it is checked electronically.
With the metal it would be a hemorrhoids, I agree for 100%!.
baltazar
A room cleaning as a room cleaning , but a warm floor should be under the tiles. I do not know how it is in Kiev, but in St. Petersburg with these floor your feet would be cold even in slippers the whole 11 months in a year ...
And, plus, it's probably the most comfortable heating!!.
constructor
Well, maybe so ... I judge the apartment – tiles are in a foyer, a hallway, a kitchen, and a bathroom. frankly speaking, I am satisfied for 100%.
Summer
Kiev is not St. Petersburg. In Turkey, in Egypt and elsewhere tiles are without heating.
Maybe, in summer, on the contrary on the ground floor because of the tiles will be the most comfortable temperature. Especially it's a summer residence.
constructor, this is an excellent performance!!. We are looking forward to continuing.
expert
As for the summer I am sure! It will be a +!. Because it is so hot in summer!.
bill
And in summer you should to swich off a warm floor. But, seriously, the warm underfloor doesn’t cost big money!!. And I personally know the people (not one person), who regretted that they had saved money on the warm floor. Thanks God it is not you!!.
constructor
We continue to warm!.
We warmed the kitchen, walls and a ceiling, a kitchen partition with a veranda / a hallway. The process is boring to horrible, but when you feel the result in the shape of a pleasant warmth, just everything falls into place. And we did not have time to close with a vapor barrier...
A gray autumn has come!. Over the weekend, we managed to mount a gutter system on two slopes and to instal the antenna. Now, you needn’t to climb on to in winter. It is not necessary!!. I didn’t think of the water course before starting the work – we needed to let down all the pipes along the north wall, as it was made on the upper slope - it would be easier to gain everything together to a drain in future. From a design standpoint it would be more harmonious. Well, it is OK and so we will collect with this design and we can live with it.
The bottom drains are still high, I will omit them for the distance when I make a facing.
Also, we had managed to trim with a vapor barrier our kitchen: walls and a ceiling. But I haven’t glued with the strapes. I hadn’t enough time.
bill
Why did you make so an output sink?. You could just pull it on the bottom. You havent done this behind the house as I understand?.
constructor
Why do I merge at one point the water from the upper slope to the bottom?.
To clean up for a couple of years a little thing from a bitumen?.
Oh no!!...I do not need it at all!.
Yes, I can not understand why do you have such trouble in your opinion?.
I walked a ramp, lowered down the tube ... it looks quite good!. IMHO ... On the back of a steep slope I did not do it. First, I simply did not do it in time, and secondly, not to do something, a head-board of the slope at a height of 4 meters above the ground – we have to upgrade the ladder and think about the insurance.
bill
Yes, I just saw somewhere that this decision was interesting. and, yes, most likely, at a high rainfall, a litter is not washed, but the dirt will be added...I do not think so.
constructor
Well, I play it safe, although I have that option sellers are offering drain as the best ... abandoned in favor of option made!
Summer
Constructor, I read everything you wrote, you are well done!! and a very careful man (in a good way)!.
We have the same pedantic dad.My mother is not happy with that slow action, and then she boasts that it is neat!.
So, (my family is ready to build. And I think, whether, in principle, are the builders, who can do their job as carefully and soundly?. Most likely, it is a rhetorical question ...
Вернуться в «Timber houses from Russia information and feedback»
