Metal hoses with a cable were packed as possible so that they passed between the layers of wool. The transverse and exits were just pierced with a knife.
Nothing complicated there. Everything is on the situation.
The heaters for a heating.
I decided with the type of electric convector for heating of the house.
There will be coils Electrolux AIR GATE ECH / AG EF.
Power will be chosen on the area.
Compared with the Noirot Spot-E3, which I have:
Advantages:
- Availability of the display there is no(in Noirot);
- Setting a specific temperature, which must be maintained in the room (for an analog controller Noirot just the numbers - it is not clear that exhibited);
- Displays the current temperature in the room;
- Possibility to work in a half-power (for the off-season);
- Presence of the filters at the air intake (mechanical, silver, catechin);
- Presence of pins in the package (not much, attached to the wall, but it is nice);
- 25% lower cost for the same power.
Disadvantages:
- Electrical safety class - 1 (from Noirot - 2), but I have a ground, so it is not so much;
- A very bright display and an indication, that creates at night some discomfort. We will seal with the tint (Noirot in dim red LED).
- Made in China (Noirot is in France) - this is the moment most embarrassing! Until now!.
To a building quality and an appearance there is not a single comment, it's very neat and beautiful!. I determined, finally, with sockets / switches for our house. It will be Hager, the series of Polo Fiorena. Everything will be standard for the installation into the built-in boxes. We will install it on adapters for the outdoor installation, which are good implemented from Polo. They gather together in groups of up to 5 items under the standard framework for built-in. It looks very nice.
The material is a polikarbonat. wall outlets of 16 amps, the terminal under a bolt. The switches for 10 amps. The terminal is self clutched. The quality of producing is good. I recommend it!. Chose the color "ivory", I think on the wood it will look great! So, futher the pictures, that will say themselves. The outlets are a block of two pieces: from the installation options of selected products for outdoor installations I declined after the consideration of their various variants. because of their inconvenience, curvature, poor appearance and poor performance.
The universal switch: I will not use the double switches, because inside the case there will not be enough space for easy and safe entry to the cable. I will put resistors in the bedrooms.
